Cadence s2w8 subwoofer 4th order
Sylosis
Would any of you enclosure gurus out there mind doing a bit of figuring for me please. the box can be 10'' wide 14'' tall and up to 29'' long. im wanting to build a 4th order for this woofer. the box will be my center console, and i want the port to exit rear to the passenger side.
here are the specs on the woofer
FO: 54.65 Hz
QMS: 7.087
QES: 0.449
QTS: 0.423
ERM: 0.709
CMS: 87.817 uM/N
MMS: 98.679 gr
MMD: 96.978 gr
NO: .180%
BL: 10.924 T/M
SPL: 93 dB
VAS: 5.298 L
RE: 1.6 Ohm
SD: 206.120 cm
XMAX: 13
woofer displacement is .04 and i want the motor mounted in the ported side
If you listen to rap and the likes I would recommend selling it. If you can get to 10 1/2" wide, you have enough airspace for a decent 10".
  • Who's Online   0 Members, 0 Anonymous, 3430 Guests (See full list)
