hey guys, this is my first post, but i got a question or 4
ok, i already read about how to hook up subs in your house (plate amp if im right) but i want to hook up my car's head unit inside my house, and then i was going to hook up some 6x9s and such to that i know it can be done because even walmart does it for their displays just wondering how to hook up the head unit
huh? did u say something?
I have had a HeadUnit and a car amp and sub hooked up in the house before.
If you have a spare computer power supply laying around try to get picks and I'll tell you how to modify it to work for car stereo.
You can purchase a power supply from radio shack for $100 that is 13.8v and is a 25amp rating. Now worth it. Too much, bought one before I knew better.
You can get a 55amp computer power supply for $100.
If you need to know how to rip apart a Power Supply I'll show you.
are you talking about the actuatl power suply (inside the computer) or like, just the cable, cuz i have an old computer layin around i can use and i dont know how to take it apart
No not just the cable. You need a power supply that will convert from 110 volts down to 12-14. I've seen people run batteries off of that as well, and have a full car stereo in the house.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
well i can just take the power supply out of my old comp then, right?
yes, the part that it plugs into (in the computer) and should have all the wires and everything on the inside
yea you can use a computer power supply
you take a ground wire and touch it to the green wire in the big bundle of wires going to the 20 pin connector.
you can splice the 2 together and use the switch on the back of it to turn it on and off.
and then you dont use anything else off the 20 pin connector.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
  • Who's Online   1 Member, 0 Anonymous, 546 Guests (See full list)
