2 Obsidian 18 v2 box
Unkown107
I have you the exact measurements to cut. There will be three pieces for the port. The vertical walls which are 6.5" by 21.75" and then the top wall of the port will be 28" by 21.75". That top piece sits down BETWEEN the two vertical pieces. That makes your internal dimensions of the port 5.75" by 28". I don't have my PC because I'm out of town and down have anything on my phone stored.
i dont even go back to work till the 2nd of jan its prolly gonna take a month for the subs just to get hear an while im waiting im gonna get the wood an drop it off to get cut idk if he will understand but i will see thanks again
Well then you have time. I can have time to get back to my computer before it's time to cut and give you exact pictures. I would think me giving exact dimensions would be pretty easy to follow. There are 3 detailed pictures and all cuts should be easy to determine with the labeling I did. The port dimensions are also written out so literally every piece is labeled and you could cut them whenever and assemble in a matter of hours.
The wood is 3/4" either MDF or nice Birch if you can find some. Not Lowes or Home Depot birch, that stuff is no good usually.
Who is this guy you're having build your box? All he has to do is read the dimensions that I've got, and make the cuts accordingly. Its only 10 pieces of wood and once he's made the cuts, he can do a mock up to see what it will look like assembled. Then he just needs to figure out the best plan of attack for actually assembling the thing.
  • Who's Online   0 Members, 0 Anonymous, 2615 Guests (See full list)
