2 Obsidian 18 v2 box
Unkown107
Home Depot will cut it, yes. Not all the dudes at the Depot take pride in their work though, just FYI. If they use the tape measure on the rack, no good. If they use an actual tape measure they carry on their belt, good. As long as they are consistent with their cuts you'll be fine. For example, if they are off 1/8" or 1/16", as long add it's off under or over each time and not back and forth you'll be able to have a square enclosure. They start getting sloppy, then you'll have work ahead of you to eat that error up later with assembly.
The cuts you'll need are ALL marked man, you don't need to understand port area or anything like that. I've done all that work for you already. You need to write down the measurements of all the pieces, there will be 10 pieces of wood. The inner baffle, you'll have to get that dimension from the side shots. Its the same width add the box and will fit on the INSIDE dimensions of the enclosure, meaning front to back it will be 1.5" less in depth.
  • Who's Online   0 Members, 0 Anonymous, 2615 Guests (See full list)
