custom sub
devongeraci
Hi I'm looking to build a 15 using a sundown basket with a ten inch spider does any one know where I can get a spider that will work with a 4 inch voice coil and a motor its probably far fetched but I would like to use a 12inch motor?
O one more thing is there a way to use 3 spiders
I would message PurpleHaze on here about building custom drivers.
He has built many of them before.
This is a link to his page: http://www.stevemeadedesigns.com/board/user/42530-purplehaze/
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
should prolly do alot more research before just putting random parts together and hoping they work well. theres different types, strenghs of spiders. and just using a coil that fits may not be the best idea either theres so many variables research alot before you try this. id hope you have a set of calipers so you can accuratly find the id,od of your motor.
also keep in mind bigger coil doesnt mean better. just because you can fit a 4k coil in something does not mean that motor has the ability to cool it
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
:NeedPics: if you have built subs in the past and are talking about production i dont think you would need to be asking these types of questions , just saying
We make every thing in house if it passes the proto phase the only thing we don't make is the spiders and drivers I have a source for both but nether can get the size I need we have modified the sundown basket to the point where we are expecting about 5.5-5.75" in movement both ways we had every thing to build the sub but thjngs got kinda out of hand and we went it that's the only reason for a 12 inch driver and a custom spider the quad coil vc was just an idea
:stfu:
  • Who's Online   0 Members, 0 Anonymous, 5110 Guests (See full list)
