finally found the specs of my subs. can u help me build this box?
GueroZ28
I have a pair k012s4 db drive 500watts svc.. i had given specs from a similar sub because i couldnt find these.. so these subs need 1.10cuft of box volume each, a port diameter of 3inches and port length of 12inches tuned to 38hz
My max dimensions are
Width- 33inches
Depth- 16inches maybe more
Height- 15inches
Going in a 03dodge neon
Powered by an 850.1 db drive amp
Looking for the dimensions i can use to get what the subs need thanks.. also im using 1/2mdf since these arent that strong
Thanks
I would not use. 1/2 in mdf use 3/4 just because they are not powerful they still make pressure which can flex the board.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
thicker wood is better. I'd still brace a tad even with the woofers being 500w. you want to eliminate all box vibration possible
Here is a suggestion for 5/8" wood thickness, also tuned a little lower which would help a bit with lower tuned music (like rap) , it can all be changed if wanted:
Assembly guide (generic dimensions):
Here is a suggestion for 3/4" wood could use 5/8" wood thickness (with some changes) but I wouldn't use 1/2" as others pointed out, also tuned a little lower which would help a bit with lower tuned music (like rap) , it can all be changed if wanted:
Looks a bit hard for me but im willing to try it.. if i use the 5/8 how would it change? For those 45s i would use the mdf also right?
Thanks youve been a real big help. How do u know all this?
I changed the above to 5/8" wood thickness so all changes made, yes, it's also MDF. Bear in mind that the amp is not rated RMS and you will be running at 2 ohm so probably won't be getting too much output from the subs.
But it will be better than the box im using right now right? I bought there at the store and fron what ive seen it isnt 3/4mdf more like 1/2mdf and if im correct its tuned at around 46hz when i entered it in the box calculator
Question: the front cut wont actually be 29 1/4"
More like 27 something like that right?
And the cut, right side of the port is a 5/8" longer than the wall next to the subs?
Ok updated the assembly style to match the pic.
  • Who's Online   0 Members, 0 Anonymous, 1510 Guests (See full list)
