best way to run 0gauge wires from battery
Hey members, need help figuring out what's the best way to setup my electrical from the battery. Should I go with (2) dual 0gauge terminal post or just buy some 0gauge terminal rings and go that route? I need to run dual power and ground to power my amp. Thanks.
2002 Nissan Altima v6 3.5
  • Four Incriminator Audio Death Penalty 15s
  • 5 Pairs DS18 Pro Audio X6.5BM
  • 3 Pairs DS18 Super Tweeters
  • Taramps TS2000x4 (Mids Amp)
  • Incriminator Audio 6.4 (Tweeter Amp)
  • Incriminator Audio 40.1 subs amp
  • Rockford Fosgate 3sixty.3
  • 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator
  • Big 3 zero gauge.
  • Excessive amperage H/O 225a
  • Alpine head unit
  • Lots of stinger deadener
Best way? I would say some custom toolmaker inputs that do exactly what you want and point the wire in the right direction!
I'm a big fan of using underhood batteries that have both top and side post, then using the side posts for the stock electrical connections, and getting some nice top post terminals to attach wiring too. remember at a minimum you're going to have 2 new wires each of positive and negative (do the big 3 when adding a system)
there are several options though and in the end it's a matter of preference.
Check here: http://www.darvex.com/store/pc/Battery-Terminals-c14.htm
Skyhigh has the multi 0 awg terminals like tool maker so does dc they are pretty reasonable, I think the cheapest way would be to use ring terminals, but in my " OPINION" the multi 1\0 terminal would look alot nicer
2003 silverado TEAM DC
Pioneer Avh 5500
4 DC lvl 5 18s
12 crescendo pwx 6.5s
4 crescendo ft1 tweets
6xs d3400s
Singer 400 alt
Skyhigh ofc wires
Skyhigh speaker wires
Smd vm1
2 DC 175.4
DC 10k
  • Big 3 zero gauge.
  • Alpine head unit
  • Big 3 zero gauge.
  • Alpine head unit
I have a 225a alt waiting to be installed. Also have a shuriken bt-80 under the hood with the big 3. Just tryin to decide which would be better! This is going in an 2002 altima 3.5L and the amp is an incriminator audio 40.1 2nd gen.
  • Big 3 zero gauge.
  • Alpine head unit
U want to have more than one pos 0 gauge to the back to ur battery bank.. I would use multi 0gauge terminal
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
Yea sorry if I didn't make that clear two runs pos n neg from the front battery to the back.
  • Big 3 zero gauge.
  • Alpine head unit
  • Who's Online   0 Members, 0 Anonymous, 3448 Guests (See full list)
