hairtrick?
Skax
i have a 1500bcdp pushing 2 rf p3 15's and cant get a hairtrick :/ i was wondering if its not enough power or should 2 p3 15's on 1500bdcp be able to pull off a hairtrick at all? :D just curious :)
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
It could do a small one, move a little bit of hair but it will not be a full hairtrick.
my goal is to be able to do a full one haha i was thinking of upgrading to a 2500bdcp??
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
What kinda vehicle is it in? You need to move a lot of air. In any sedan you almost need to wall it to achieve a full on hair trick.
Upgrading the amp probably wont help a whole lot, maybe a little. The key is to design the enclosure to move a lot of air, the vehicle its in makes a huge difference as well.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
yea i got a 2000 saturn l series
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Yeah its going to be hard to pull off a hair trick. Sealing off the trunk will definitely help move air in the cabin.
B5 Passat Build Log
wonder how much it would cost a shop to build a wall vs sealing it off or how hard would it be to seal myself?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
A lot.
It's not too hard to build a box and seal it. Building it yourself is a big part of the fun in this hobby. You get to build it how you want and make it yours.
If you went the shop route:
You would also have to find a shop that would know what they are doing when it comes to that.
Most shops just install alarms and toss subs in prefab boxes.
B5 Passat Build Log
A lot.
i bought the 15's and the box they came with was dry rotted or somthing so i just bought a prefab box because ive been told a custom box wouldnt fit since the prefab barely does. so how would i go about sealing it off the best way ??
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
You would want to build panels that fit tight in the trunk and seal off from behind using different materials. I used deadener, foil tape, duct tape, and spray foam.
Your best bet would be to read though some of the build logs with sealed trunks to get some ideas on how to do it. There are quite a few here. I have mine but it was my first one I'm sure there are better here.
B5 Passat Build Log
  • Who's Online   0 Members, 0 Anonymous, 5110 Guests (See full list)
