box design help?
Skax
ok so im ganna get my dimensions for my box and get it sketched and BigGains is ganna help me build it but i need to know should i do any of the following?? also the box will be ported
Preferred Tuning Frequency
45° In Corners? [?]
Rounded Port Corners? [?]
Kerfed Port Opening? [?]
Flush Baffle? [?]
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Subs size? Brand? Flush baffles look better but a normal double is stronger. And I personally like tuningmy boxes between 32 aand 35 but that's just me
Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird..
He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke.
2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe
subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12
Amp: pioneer gm9061 amp: poineer gm9601
headunit: kenwood kdc 255u mids: SQ pro mids
midbass: polk db 8s highs: stock
mids/highs: shitty off brand
2 15's p3 rockfords , and so no flush? and around 33hz??
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
I would put them in a 7 cube ported box and the sounds like a good tuning but tuning is just a personal preference. Lower turning will let u hit deeper bass better and generally a little higher tuning like 35 will give u a little more Spl but not as loud in the low low bass.
Rockford recommends them 2.5-3 each, I would put both in 5 cubic feet and if I remember right you were going to run them on a ct 1400 so that would be close to the max wattage
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
i would def 45° the corners, and if they were my 15s i would tune at 30hz.
what is a kerfed port opening?
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
  • Who's Online   0 Members, 0 Anonymous, 4755 Guests (See full list)
