Box design help?!? does this look good?
alenv10
next to sub displacement is a box for extra baffles, you need to put a 1 there. it will decrease box volume a bit to so you will have to make a slight adjustment to box size as well.
since the sub isn't loading directly into the port it shouldn't be an issue. ive seen and heard ( even had a similar box ) and didn't have issues with it.
oh and the torres box calc is off on tunning. google search car audio box tuning calculator and use a few different calcs to check tuning freq or do the math yourself.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
its off by a different amount per box design. its best to just check your port tuning on more then one calc to make sure its with in a range you are looking for.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   1 Member, 0 Anonymous, 801 Guests (See full list)
