biggdaddyb26 Posted January 11, 2014 Report Posted January 11, 2014 I want to build a vented enclosure for 2 L7 15' need some help with size want it to hit hard
Flatsfisher8 Posted January 11, 2014 Report Posted January 11, 2014 What kind of vehicle, how much space do we have to work with? Have you had previous experience with enclosures?
RCP Audio Posted January 11, 2014 Report Posted January 11, 2014 Post in the correct section and someone will be able to help you. But if this is for your house or your home. Post up some more details PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
CleanSierra Posted January 11, 2014 Report Posted January 11, 2014 Welcome to the forum. As mentioned, post vehicle, what you'll be powering the subs with, the Voice coil configuration(Dual 4, dual 2) ,music you listen to, etc. Go grab some dimensions of your trunk or cargo area to determine if they'll fit properly. Do you own the subwoofers already? Im not the one you want to try to troll. Just a fyi for you.
biggdaddyb26 Posted January 11, 2014 Author Report Posted January 11, 2014 I have a 86 Chevy p/u with a bed cut and a bed cover so I have attached that space in the back
