Sky High ring terminal fuse holders
I read a thread lately that someone was having trouble fitting the 1/0 copper ring terminal into the fuse holder. Well I got mine today and this is what I did to make them fit perfect. The top clicks right on with no contact with the top cover. Only thing you need to do is push the ring terminal inwards before you tighten them down as that will give you a little more room.
All I will do is add a couple small washers under the ring terminal for a little more contact but it wont effect the height and the cover fits with no problems.
Hope this helps.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Time to do some soldering :-)
2003 silverado TEAM DC
Pioneer Avh 5500
4 DC lvl 5 18s
12 crescendo pwx 6.5s
4 crescendo ft1 tweets
6xs d3400s
Singer 400 alt
Skyhigh ofc wires
Skyhigh speaker wires
Smd vm1
2 DC 175.4
DC 10k
Thanks. I see what you did different. I put the fuse and the lugs between the nuts. I wanted metal to metal contact on both sides of the lugs with the shortest path for current to flow from fuse to lug. But I don't think I mounted them as they intended.
Thats why I will do a short stack of copper washers on the bottom for that.
80prs
DC 180 alt
  • Who's Online   0 Members, 0 Anonymous, 3249 Guests (See full list)
