Is a sundown sa-12 and kicker Dx1000.1 a good combo?
Samantha Medina
Welcome to the forum Samantha. Is the amp 1000 watts at 1ohm? Are subs dvc4 or dvc2?
truthsayer
If your carefull and set the gain right you should be ok on the 1,000. But the sq1200 would be pushing your luck. But the sq1200 would be a good match for 2 sa's.
truthsayer
I'll probably go with the 1000, the 2011 Dx1000.1 is 1000 rms at 2 ohms so I will go with the d4 and set it up at 2 ohms and maybe later down the road when my bass needs grow I will get another d4 and go with a SQ, thanks for your help
sq1200 would be more efficient than the kicker amp I would assume. Like truth said, if you have a CLEAN signal to the sub and a proper box, the sa12 can handle it. You would just have to pay attention. If it starts to get stinky turn down the volume.
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
  • Who's Online   0 Members, 0 Anonymous, 651 Guests (See full list)
