Home amp picking up radio?
its definatly a grounding issue, some devices have a ground lift switch that will often solve it. or try grounding it. It should have a grounding pole for when your using 2pin gear, connect that pole to a device that has 3 pins going into the wall (make sure its on the same plug though so you dont get voltage differences.
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
  • Who's Online   0 Members, 0 Anonymous, 1228 Guests (See full list)
