2012 Mustang Sundown and FI
Well wanted to switch everything up and do a nice clean trunk build this time around. Usually all my builds i do i like to make easily removable and I really like to be able to get to everything easy also, Very limited on what I could stick in the Trunk. The mouth opening is not very big and I only have at most bout 11" clearance if i want to slide enclosure from inside of mustang into the trunk. Luckily i was able to finagle the enclosure into the trunk so 1 12" is all I could do but pretty excited to get it all up and running again. Been with out bass for a little
So as always everything cut and test fitted real quick
Got the inside all coated and screw heads covered
Decided i wanted the terminal cup up top so everything is real easy to get to so cut the hole for that then went ahead and wrapped the enclosure in black Vinyl
Well never tried an FI woofer before, had plenty of friends that have ran them so went ahead and grabbed one to see how I like it. FI had a killer deal going on for this past black friday so I jumped on it and Got a 12" SSD Fully loaded, Have to say Looks pretty sexy!
With limited room I wanted to put the amp on top of the box since the 4 channel i have will be placed elsewhere so started getting some ideas of how i want to mount it so went ahead and cut out the piece for that
Did a quick test fit in the trunk again to double check everything and I'm really diggin the layout of everything so far
