la negra Posted January 17, 2014 Report Posted January 17, 2014 1st off thanks for any advice given. I greatly appreciate it. Heres the specs for a fi n2 15 sub box going in a 01 tahoe. Now my question is when I played with box dimension the ports were internal, but with the layout of sub up ports forward. I have to run them half way externally side by side. So does tuning change? I do know air space does which is fine. Im shooting for 5 cu anyways. It will be a daily box on 2k eventually(1k now). Numbers are not important
alaskanzx5 Posted January 17, 2014 Report Posted January 17, 2014 I'm fairly certain it does. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
la negra Posted January 17, 2014 Author Report Posted January 17, 2014 Droping a hz is not a bad thing. I dont wanna go lower than 32hz or higher than 34hz . I can always make the port shorter. I have two 24in pvc's to cut down to size Thanks fellas keep them answers coming.
alaskanzx5 Posted January 17, 2014 Report Posted January 17, 2014 Google search how to flare the pvc. Basically a metal bowl and,a heat fun. Heat the pvc and push it down on an upside down metal bowl. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
la negra Posted January 18, 2014 Author Report Posted January 18, 2014 I have flared end too. Just need to cut the middle section. Should have said so to begin with.
la negra Posted January 18, 2014 Author Report Posted January 18, 2014 Morning bump anybody else care to chime in. Box is as already started.
