Enclosure Build: SA-12, kerfed port
Another WooferWarehouse enclosure build. This will be for a single SA-12 and will feature a kerfed port like the title suggests.
Specs come to:
-2 cubic feet net
-35hz tuning
-29.25 sq inches of port area
The design:
Getting started...
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
45s in the corners and terminal cup hole cut+rounded over.
Obviously not all parts are mounted. Just need to get everything mounted, cleaned up and the rabbet continued over on the kerfed panel to help with carpeting.
Alright...structurally finished, onto carpeting...
Team Tupperware
Not the prettiest soldering, but it's solid.
Team Tupperware
looks good but why didnt you kerf all the way around instead of just the mouth of the port
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
