eazy Posted March 9, 2008 Report Share Posted March 9, 2008 I've got a Sundown Audio SAE-1000D on it right now and it's barely moving... loud as hell... but barely moving. What do you think would be a better match for it? Quote 1999 Mercury Grand Marquis LS Build Thread Pioneer DEH-P5000UB (4) Infinity Kappa 682.7CF's Sundown Audio SAE-1000D Sundown Audio SAX-100.4 Fi Q15 with BP power in 4 cubes @ 32Hz (2) Kinetik HC1800's Duralast Gold Group 65 Excessive Amperage 250A alternator Knukonceptz Kolossus 1/0 gauge Elemental Designs eDead v1SE² Link to comment Share on other sites More sharing options...
KWP369 Posted March 9, 2008 Report Share Posted March 9, 2008 wats the voice coil on it and that might generate a better answers... also try lookin through the general audio section, amp section, or even the subwoofer section. not mad at yea but it seems everytime i get on this question is asked? Quote Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs Link to comment Share on other sites More sharing options...
KWP369 Posted March 9, 2008 Report Share Posted March 9, 2008 another thing is if u have dual 2 ohm then do u have it wired for 1 ohm or 4 ohms, cuz if it's wired for 4 ohms then thats why it ain't movin, if u have the dual 4 ohm then u can't go below 2 ohms. and i believe the Sundown Audio SAE-1000D only puts out like 600-650 watts at 2 ohms. also if u have the dual 4 ohm then it's possible u have it wired down to 8 ohms and then ur sub definatley ain't seein no watts Quote Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs Link to comment Share on other sites More sharing options...
KWP369 Posted March 9, 2008 Report Share Posted March 9, 2008 (edited) here i did some work for u.... if you have the dual 2 ohm vc then click here Click ME your goin to scroll down to the diagrams and then use diagram number one Edited March 9, 2008 by KWP369 Quote Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs Link to comment Share on other sites More sharing options...
kevinb721 Posted March 9, 2008 Report Share Posted March 9, 2008 (edited) I've got a Sundown Audio SAE-1000D on it right now and it's barely moving... loud as hell... but barely moving. What do you think would be a better match for it? that shit should be movin...i got one 12q runnin on a rf t10001 and that shit beats like hell like kw said check your wiring maybe you have it wired for 4 ohms instead of 1 which it should be at Edited March 9, 2008 by kevinb721 Quote 12" fi q rf t10001 naw mean Link to comment Share on other sites More sharing options...
KWP369 Posted March 9, 2008 Report Share Posted March 9, 2008 (edited) that shit should be movin...i got one 12q runnin on a rf t10001 and that shit beats like helllike kw said check your wiring maybe you have it wired for 4 ohms or even 2 instead of 1 which it should be at i don't know his car audio skills but i'm thinkin he either has his gain all the way down or it's wired down the the highest ohm for the vc that he has Edited March 9, 2008 by KWP369 Quote Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs Link to comment Share on other sites More sharing options...
kevinb721 Posted March 9, 2008 Report Share Posted March 9, 2008 Quote 12" fi q rf t10001 naw mean Link to comment Share on other sites More sharing options...
KWP369 Posted March 9, 2008 Report Share Posted March 9, 2008 (edited) yea i gave him the link for the dual 2 ohm vc Edited March 9, 2008 by KWP369 Quote Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs Link to comment Share on other sites More sharing options...
AI James Posted March 9, 2008 Report Share Posted March 9, 2008 he cant have a dual 4 vc on a q, also it could be in his settings somewhere at i had a 15q on a piece of shit Xterminator amp about 900watts and slamming it. Quote Link to comment Share on other sites More sharing options...
KWP369 Posted March 9, 2008 Report Share Posted March 9, 2008 (edited) he cant have a dual 4 vc on a q, also it could be in his settings somewhere at i had a 15q on a piece of shit Xterminator amp about 900watts and slamming it. doh.... they come in 1 ohm dvc or 2 ohm dvc... (dumbass me), so since the woofer wiring wizard at rockford only goes down to 2 ohm dvc how do u come up wit wiring for a 1 ohm dvc? Edited March 9, 2008 by KWP369 Quote Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs Link to comment Share on other sites More sharing options...
