Great Watt Per Dollar Amp
TZspeakersZac
http://www.xplicitaudio.com/pure-audio-pa-3000-1d/
Has anyone clamped one of these? Seems way too good to be true... But you never know, seems like it might be a new company. If you have used it, is it dirty?
Guts look good...
its the same shit as audiopipe. two audiopipe 1500's in one casing. lowest you can wire is 2 ohms because each amp sees 1 ohm.
try running that at 1 ohm strapped (it says it can run that) and see what happens LOL
edit: my ap1500 caught fire. and there are two of those in that case.
edit 2: serious answer, it will do literally 2000rms at 2 ohms (each amp board inside sees 1 ohm) and probably blow up at 1 ohm.
I just did some reading on these, and compared internals of the amps that I read about. It doesn't look the same as the AP, but I also read it's the same as an older unnamed TREO amp. Maybe I should just get one and clamp and see.
Edit: Board looks like AP, but the components (caps etc) are different.
Nah man, it's cuz of the bass.
same buildhouse. once I see something GOOD from that buildhouse, I might change my mindset
  • Who's Online   0 Members, 0 Anonymous, 5638 Guests (See full list)
