MyimpalaFinLBS Posted January 29, 2014 Report Posted January 29, 2014 he older 99-00 model dual 2ohm HCCA 15's with the TC 9 motor I believe. For now I will be running a RF x7a which pushes a little over 1800@2ohm. I will eventually upgrade to double that power. These are going in a 2008 Impala LS. My max dimensions are W- 36" H- 17" and D- 40". I would like to run them in about 9ft^3 with a single large aeroport in the center. Can someone please help me so I don't rack it up....I really can't afford to do that.
jarrius Posted January 29, 2014 Report Posted January 29, 2014 If i where you before i did anything i would get some cardbord and make a fake box and see if you can fit it in the trunk. If you cant then make it a bit smaller and smaller till you can. Otherwise i for see you having to build the box in the trunk for those 2 15's. Also double check your hight to make sure with 17in tall you can still close your trunk. Dont want to build it and trunk lid not close 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
MyimpalaFinLBS Posted January 29, 2014 Author Report Posted January 29, 2014 Normally that wouldn't be an issue but it seems the temperature here barely gets to double digits all day. I don't have an issue building inside the trunk if it won't slide in though. If anyone can get me a design within my max dimensions it would be much appreciated.
MyimpalaFinLBS Posted January 30, 2014 Author Report Posted January 30, 2014 Any help with a design/cut sheet....I'll gladly pay for it...
Joe X Posted January 31, 2014 Report Posted January 31, 2014 BTW the software used is Torres calculator, if you want to tweak a bit the above you can download it from this site.
MyimpalaFinLBS Posted January 31, 2014 Author Report Posted January 31, 2014 I tried to download it but its not working on my tablet...that box is exactly what I'm looking for but my max width is 36"..,can it be adjusted by masking at a bit deeper? And thank you very much Joe...I reaaaallly appreciate the help.
Joe X Posted January 31, 2014 Report Posted January 31, 2014 Yes, this program only works on windows, anyways your subs would need to be 15 1/2" overall diameter for this to work and I hope you could find a little more than 36"w since your port area is lower than I'd like to see.
MyimpalaFinLBS Posted January 31, 2014 Author Report Posted January 31, 2014 What do you mean 15 1/2" overall diameter? Are you talking mounting holes? We got into the 30 degree range today so let me get a cardboard mock up of this and I'll see if I can squeeze any more width out of it.
Joe X Posted January 31, 2014 Report Posted January 31, 2014 What do you mean 15 1/2" overall diameter? Are you talking mounting holes? We got into the 30 degree range today so let me get a cardboard mock up of this and I'll see if I can squeeze any more width out of it. No the overall diameter (which is the maximum external diameter) accounts for the minimum width of the baffle, in the above, the baffle would need to be 15 1/2" + 15 1/2" + 5 1/8" = 36 1/8" wide which is what I gave as baffle width, just make sure those are that size (which I am almost sure they are).
