Weechaz Posted January 29, 2014 Report Posted January 29, 2014 Hey guys, I really want to do a wall in my 1997 four door Tahoe. I'm wanting to do 6 or 8 15's and keep the back seats. I could really use some help with an enclosure design. I was wondering if anybody could help me out or tell me if it is possible. Subs-SoundQubed HDS315 for now. Amps--Undecided Electrical--Xs d3400 in rear, Stock up front, new Alt coming when taxes get here. Thanks in advance! @therealweechaz
agf144 Posted January 29, 2014 Report Posted January 29, 2014 you coud probably do 6 15s at most but not keep the backseats. that wont fit Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
jarrius Posted January 29, 2014 Report Posted January 29, 2014 First whats your budget? Expect to pay as much if not more for electrical upgrades as you do for your equipment. Second i really dont think you will have the room for a c piller wall and the batts and amps if you do 6-8 15's. Imo 4 15's in a c piller wall should work depending on space. If im wrong some one correct me. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Guest Posted January 29, 2014 Report Posted January 29, 2014 you can probably do 4 18's in a flatwall. i know a guy around me that has a suburban with 4 18" sundown woofers. does 157's. demos are mean, and flex city... he's on this forum...but i forget his name. edit: but of course suburbans are longer than tahoes, so you probably wont have the depth to get the required space for 18's. edit 2: i think his forum name is svb847. same as his youtube name.
AA98hoe Posted January 29, 2014 Report Posted January 29, 2014 Not worth it from c- pillar it won't be any louder than no wall TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Weechaz Posted January 29, 2014 Author Report Posted January 29, 2014 Budget will be somewhere around $5000 and would i be better off just doing a ported box? @therealweechaz
Popwarhomie Posted January 29, 2014 Report Posted January 29, 2014 With a budget of $5k why not just do 4 18s. 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build.
AA98hoe Posted January 29, 2014 Report Posted January 29, 2014 In that year Tahoe maybe choice is yours tho TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
SlamminBeats Posted January 29, 2014 Report Posted January 29, 2014 all those woofers and your gonna run 2 batteries and one is stock and the other is a smaller xs? i think you ahead of yourself on this to be honest.
Weechaz Posted January 29, 2014 Author Report Posted January 29, 2014 No, I'm going to get a new alt when taxes get here and start getting a bank of batteries set up this spring , I was just curious as to weather or not it would be possible. @therealweechaz
