Triticum Agricolam Posted February 2, 2014 Report Posted February 2, 2014 how much bigger if the sub displaces 0.17 cuft I think you just answered your own question. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Desousa93 Posted February 2, 2014 Author Report Posted February 2, 2014 how much bigger if the sub displaces 0.17 cuft I think you just answered your own question. if it still falls into the sealed optimal displacement i could keep it and make it 1.33cuft sealed and 1.5cuft ported.. it barely changed on winisd New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Desousa93 Posted February 2, 2014 Author Report Posted February 2, 2014 i got this been working for 2 hours (my first time on sketchup) but this is my plan for the box. external part of port will go thru armrest Green is the Xcon Red is the port New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Triticum Agricolam Posted February 3, 2014 Report Posted February 3, 2014 Looks like you are making good progress. I'm afraid your port might end too close to the back wall though. You want it to be at least one port width away. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Desousa93 Posted February 3, 2014 Author Report Posted February 3, 2014 So in my case 6" away? New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Triticum Agricolam Posted February 3, 2014 Report Posted February 3, 2014 Yeah, if you had it 6" away that should be just fine. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Desousa93 Posted February 3, 2014 Author Report Posted February 3, 2014 might say screw the 4th order and do a regular ported box.. i have roughly 5.8 cu ft to work with.. maybe 2 12's Xcons in 5.5 cu ft tuned to 27 hz? lol 16"x31.5"x20 = 10,080 cu Inches = 5.83 cu ft? (outer dimensions...thanks Triticum) New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Triticum Agricolam Posted February 3, 2014 Report Posted February 3, 2014 Just keep in mind the dimensions you used were the outside of the box, its the inside that matters. Assuming 3/4" material you get 14.5" x 30" x 18.5" = 4.65 cubic feet. If you use a double baffle, which would be a good idea, you will end up with even less. So out of that 4.65 you have to subtract the space the subs use up, which for 12" Xcons is .17 cu ft each, and the space the port is going to use up, which could be anywhere from .5 to 1.0+ cubic feet, depending on the style of port. So now you are left with 3.3-3.8 cu ft of net airspace. This is what your subs will see and is the number that matters. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Desousa93 Posted February 3, 2014 Author Report Posted February 3, 2014 3.3-3.8 cu ft.. hmmm maybe one 12 xcon ported? can i run the sub facing the trunk and the port thru the arm rest? New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Triticum Agricolam Posted February 3, 2014 Report Posted February 3, 2014 3.3-3.8 cu ft.. hmmm maybe one 12 xcon ported? can i run the sub facing the trunk and the port thru the arm rest? If sound quality is of any importance to you you want the sub and port to be close together. Its one thing to do subs up, port back in a SUV where they are both firing into the same space, but to do sub back, port through the arm rest would not be a good idea IMHO. The output from each is not going to integrate together like you want it to at all. If you want the most output the best option would be to have both the sub and port forward and seal the box and cabin off from the rest of the trunk. If you don't want to do that do sub back, port back. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
