if you wire two subs together in series as to where you will have 5 pairs of subs sitting at 8ohms... then wire them all together in parallel you can get 1.6ohms...
i likes me some audio stuff...
so if i had 3 subs and i wired 2 in a series and one in parallel in one chanel i will have ............ ohms
If you did that, the sub wired parallel would recieve the same amount of power that BOTH the others would see, I think. You would have weird ohms too, something like 5 or 6 ohms.
