Which subs should I get?
GueroZ28
I was already planning on getting the HDS2 12s but no one can give me a review on them .. I just hear theyre good subs for the price. but are they good subs in general? im looking for subs with about that much power or about 500watts rms dual voice coil. for a max pay off 100$ each.. but maybe there are some that are considered better than those hds.. thanks.
any other advice would be great thanks
already have an amp for the subs just need the subs
That's probably one of the best choices for only 100 bucks a piece
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
I would say those are the best you are gunna find
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
so I would be satisfied right? just want to make sure I get the right ones
also does it matter if the amp I use is a 1050watt monoblock instead of a 1200watt?
? if there 500w a piece you want at least 1000w Amp. but really any amp between 750w and 1200w will be fine. i wouldn't go any more because cheap subs usually barely do there rated power. i would buy one good sub for $200 instead of 2 ok subs for $200!! especially if you get used! you can get fi bls all day for $200 that would be my choice! even more so if your Amp is truly putting out a clean 1000w what Amp are you running?
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
but would it sound the same or better or what?? ill be using a db drive 1050watt monoblock
by the same I mean as loud I want it to be felt a lot
your budget will be your determining factor. You get more cone area out of 2 10s than 1 12 so I'd stick with the 2 10s....But for a more budget minded system, the differences in the companies mentioned compared to power your providing them with are miniscule and you'll probably hear no audible difference.
Same principle applied to 2 12s right?
  • Who's Online   0 Members, 0 Anonymous, 2855 Guests (See full list)
