Powerslave Posted February 7, 2014 Report Posted February 7, 2014 Hi. Thanks for reading this. I have a PA660.4 4 channel amp powering 4 kicker cs65 6.5 speakers. My HU is a Sony BT4100P. I have no sub at this stage. I am not sure if my amp should be set to "full" or "HPF" for my speakers. Also, I would like to use my HU for the frequencey and not the amp's crossovers. As my amp does not have the option to turn off the crossovers, I am not sure what to set them at to use the HU crossover. Do I turn them all the way down? to 50 hz? or all the way up to 500 hz? Thanks for your help as I could not find any info in the search for this.
BoomZoom808 Posted February 7, 2014 Report Posted February 7, 2014 Most door speakers cant effectively play below 60hz set the amp to full and the head unit hpf to anywhere between 50-80hz 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Powerslave Posted February 7, 2014 Author Report Posted February 7, 2014 Ok. Thanks. But I'm still not sure what to set my amps crosseover to as far as the hz go. 50hz or 500hz. I can't just turn that off. Not sure if whatever it is set at would interfer with the HU settings.
BoomZoom808 Posted February 7, 2014 Report Posted February 7, 2014 If it's fixed use hpf 50 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
