XmaximuS Posted February 24, 2014 Report Posted February 24, 2014 Because bass boosts are the devil of car audio... Technically if your setup is done right you shouldn't need it with any amp .. X MY BUILD LOG>>>> NAH I BETTER NOT..
Hammer Knock Posted February 24, 2014 Author Report Posted February 24, 2014 right. so im wondering why it would need it just to sound as loud as the ap3k. no distortion and same vol on head unit. ap3k @4 ohm 1800 watt opti6k @4 ohm 3000 watt. just really dont see why the opti6k needs bass boost to hit like the ap3k with no bass boost? if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL
XmaximuS Posted February 24, 2014 Report Posted February 24, 2014 Just sounds like that the opti is dialed in right... X MY BUILD LOG>>>> NAH I BETTER NOT..
Guest Posted February 24, 2014 Report Posted February 24, 2014 audiopipe doesn't do rated. i dont believe the opti 6k does either. different gain sensitivities on the two amps. go through every single dd-1 step thats in the manual, again. using the -5db track.
XmaximuS Posted February 24, 2014 Report Posted February 24, 2014 Both amps are fine. You just gotta do some tweaking .. I hope this thread don't turn into an amp bashing segment(again)... X MY BUILD LOG>>>> NAH I BETTER NOT..
Hammer Knock Posted February 25, 2014 Author Report Posted February 25, 2014 right. and idc what anybody says. i know the ap3k smashes. because of this. and its possibly because its @4 ohm. and not being rated, is not the cause in this case. if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL
Hammer Knock Posted February 25, 2014 Author Report Posted February 25, 2014 audiopipe doesn't do rated. i dont believe the opti 6k does either. different gain sensitivities on the two amps. go through every single dd-1 step thats in the manual, again. using the -5db track. would love to see vids of these amps on the dyno XD. but another track may help. i only did track 3 on the amp i believe. if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL
01 S-10 Posted February 25, 2014 Report Posted February 25, 2014 audiopipe doesn't do rated. i dont believe the opti 6k does either. different gain sensitivities on the two amps. go through every single dd-1 step thats in the manual, again. using the -5db track. I have the opti 6k, And it does do rated. They have been clamped many times TDH FTW !!!
01 S-10 Posted February 25, 2014 Report Posted February 25, 2014 Op your doing something wrong, I went from a 3k amp to the opti 6k and the difference was huge! TDH FTW !!!
Phaeton Posted February 25, 2014 Report Posted February 25, 2014 audiopipe doesn't do rated. i dont believe the opti 6k does either. different gain sensitivities on the two amps. go through every single dd-1 step thats in the manual, again. using the -5db track. would love to see vids of these amps on the dyno XD. but another track may help. i only did track 3 on the amp i believe. i got a audiopoop ap30001. if steve is willing to use it on the amp dyno, i'll send it. plus its a piece of shit. my mb quart oa1000.1 was louder. And the audiopipe is only a 2k amp. you can tell by the fuse it comes with, 1997 subaru legacy outback Four 15's in a almost wall Rockford Fosgate t2500-1bdcp Rockford Fosgate T400-4 on tweets Rockford Fosgate T400-4 on highs Rockford Fosgate T400-2 on midrange Rockford Fosgate T400-2 on midbass Optima Yellow top batteries 270A Singer alt (working on a bracket for a second) Lots of Second Skin
