3 opti1233d trunk wall?
Hammer Knock
Op your doing something wrong, I went from a 3k amp to the opti 6k and the difference was huge!
from what ohm load to what ohm load?
if the car doesn't stall, you have enough voltage.
DEH-6400BT
BC3500D on 2 x 12" Lanzar Opti1233d
QBOMB 4.5cu
1/0 awg, Lanzar AMPKIT0
Singer 275 + LCAKT50DBL
audiopipe doesn't do rated. i dont believe the opti 6k does either.
different gain sensitivities on the two amps.
go through every single dd-1 step thats in the manual, again. using the -5db track.
would love to see vids of these amps on the dyno XD. but another track may help. i only did track 3 on the amp i believe.
i got a audiopoop ap30001. if steve is willing to use it on the amp dyno, i'll send it. plus its a piece of shit. my mb quart oa1000.1 was louder. And the audiopipe is only a 2k amp. you can tell by the fuse it comes with,
2 x 50 amp fuses? really doughtfull! love to see that over any amp dyno test right there!
DEH-6400BT
QBOMB 4.5cu
and yet again. either way!? whats this have to do with bass boost? and the comparing of it?
DEH-6400BT
QBOMB 4.5cu
.67 on the 3k to .5 on the opti
TDH FTW !!!
Also iirc the opti 6k is rated at 2000 watts at 4 ohm, not 3000
TDH FTW !!!
so if I wire to around 1 ohm load I would see the diff without the bass boost?
DEH-6400BT
QBOMB 4.5cu
and how only 2k?
DEH-6400BT
QBOMB 4.5cu
the 3k has been? :o
DEH-6400BT
QBOMB 4.5cu
  • Who's Online   0 Members, 0 Anonymous, 6242 Guests (See full list)
