You won't be able to tell from the specs unless they specifically mention differential inputs.
Some companies advertise it, some don't.
They are generally used in higher end amps since there is more circuitry involved which filters out common mode noise and gives you a larger/cleaner input signal.
Any reputable company should have a technical support team that can tell you if their product supports a differential signal.
If they can't or won't...walk away. ;)
Also keep in mind that your device (HU) sending the signal MUST output a differential signal for the noise cancellation to work.
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Hmm, none that I can think of offhand.
There are solutions though.
Fosgate makes a Line Driver module that will output differential signals.
http://www.rockfordfosgate.com/products/details/rf-bld
Or you can get an external processor (360.3) that does the same.
Not that many people like buying extra equipment but there are options.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
If you have noise that you need to get rid of then they could definitely be worth it.
If your (unbalanced) signals are clean and you you're happy with it then no its probably not worth it, unless you want some of the other features of the device.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
