Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
Do you know anyone that makes these for reasonable prices?
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
this is the plan and cut list. I don't remember who sent me this but it is a great design and absolutely bangs!
For the double box: (This is looking at the lower drawing on the left)
Top -27x18
Bottom -32.25x18
Port side -15.75x18
Side -15x18
Piece(1) -9.75x18
Piece(2) -21x18
Piece(3) -21.75x18
Front/Back -32.25x16.5
For the single box: (Looking at the lower right)
Top -27x8.75
Bottom -32.25x8.75
Port side -15.75x8.75
Side -15x8.75
Piece(1) -9.75x8.75
Piece(2) -21x8.75
Piece(3) -21.75x8.75
Top/Bottom -32.25x16.5
The subs are 5.625 or 5/8" from the outside of the box.
i want to do a tline, can anyone help me with a design? i want to use a type r 1043d, and a alpine pdx 1.600
Fs 31, Qms 87.9, Qts .53, sd cone area is 332 cm2
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
I might throw something out there for ya
This should work out just fine
I measured it to about 31.5 - 32hz
thanks man, i just gotta squeeze it into a pt cruiser now lol
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
what is your measurements needed?
i just took measurements and if i cut the little shelf slots off it will fit, but it will have to face up
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
Would I be able to do either a DC Lvl 4 XL 18 or Lvl 5 18 or BTL 18???
http://www.youtube.c...er/SmallTownSPL
2002 Chevy Blazer
Substage: Shhh, its a secret ;)
Mids and Highs: Stock-Going to change soon
Amp:MTX 92001
Wire:1/0 Welding cable
Electrical:Stock
http://www.stevemead...__fromsearch__1
I hope she was meaning that to you. Any who.... You dont say you wanna have dinner in the first damn post. talk to her first. I say find out if the status was torwards you..
Here try this...
"Hey hows it going :)( notice smiley face makes everything better ) I saw your status. "You are far from usual".... So is my dick... Wanna Fuck tommorow???"
Or send her message saying "hey" she replies back "hey" when this happens reply Wanna fuck (INSERT ADDRESS HERE)
Quote of the SPL Creed ; back in the day my girlfriend gave me a choice between her and my love for car audio, I told that bitch I've made harder decisions at the Coke machine. :)
I read all of this and I'm still a lil confused but I get the basics. I'm wondering if I can build a t-line box for my 2 12" Alpine Type R's? Here's the specs of them.
Nominal Impendance 4ohm+4ohm
Frequency Response 23-500Hz
Sensitivity (SPL@1W/1m) 85 dB
D.C Coil Resistance (Re) 3.7ohm+3.7ohm
Inductance (Le) 1kHz/20kHz 3.71mH/1.67mH
Free Air Resonance (Fs) 29Hz
Equivalent Stiffness (Vas) 45L (1.6 ft^3)
Mechanical Q (Qms) 7.89
Electrical Q (Qes) .50
Total Q (Qts) .47
Linear Excursion [(Hvc-Hag)/2)], One-Way (Xmax) 18.2 mm
Magnetic Linear Excursion, One-Way (Xmag) 19.4 mm
Mechanical Excursion, Peak-to-Peak 65 mm
Gap Height (Hag) 10 mm
Coil Height (Hvc) 46.4 mm
Cone Area (Sd) 480 cm^2
Voice Coil Diameter 50 mm (2")
Magnet Weight 109 oz
I'm going to put them in a ford f150 extended cab. Here's the measurements of the space I have to work with 41" height, 58" width, 25" depth. Oh and will this box be heart stopping loud and shake windows? Maybe do hairtricks?
