Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
I have a question. Could I have the area of the line a little less than the cone area of the woofer? If I go with the setup I'm currently thinking about, I'd only be short by about 15 sq. inches.
I'd also be running it at more than it's RMS (but not by much).
15.4" widescreen
128MB shared video memory
Windows 7 Home Premium 64 bit
What it does:
On a USB 2.0 Wireless card
Anyone?
15.4" widescreen
What it does:
if you have a bigger subs 12-15" sub, i dont see it being a problem.
Yeah, I was thinking (1) 12" sub off of about 3-400 more then it's RMS.
BTW, does anyone have any experience with a 12" in a Tline? I know it'll be loud, but I just want to know how ya'll liked it?
EDIT: I just re-read the entire thing. Forevrbumpn said putting more than RMS to a sub could damage the sub. I don't want to do that. Oh well, I don't mind giving up too much power. Thanks for the info though.
EDIT: Oh, and BTW, I just figured out how to gain about 5 or so sq. inches of area. I'm getting closer. Unless anyone thinks I should just get a 10".
EDIT: I re-read the first post. Forevrbumpn, why did you use 80 sq. inches per 12"? Could I also do the same? If so, I'd have more than enough room. I was thinking I needed about 113 sq. inches in my Tline.
EDIT # 264236849: Just re-read again. I keep missing cr@p. Anyway, all of my questions are now answered. I'm ready to get some wood and get building. Then, I'll need to find a good amp and order my sub. That'll be a while, but I'll get on it ASAP.
Thanks for the Tutorial Forevrbumpn. It helped me a lot.
15.4" widescreen
What it does:
this is a t-line I just worked up for an MTX 5508-04. Its gonna be 39.201 Hz Line length is 86.5" Fs is 40.52Hz, recamended tuning is 38Hz. so I figured 39.26Hz would work great.
can somebody check my math and see if I got this all right? iIf you can't see it that well I'm sorry, ask whaever you need to, I will let you know, Thanks, I hope Foreverbumpin will see this. Also the reason it is the way it is, is I needed it to be between the shocktowers, and this is the only way I could think to get the port and driver on the face of the box. Thanks
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
I must say, freaking awesome post :) I'm gonna try this on one of my 12"in kicker Comps.
Qts is a lil high (.47ish) but Qms is like 11.something :) so it might work I think. And I'm gonna try it at its fs of 25.8hz.
with these specifications I came up with a box that is 3 (2/3)ft x 1.5ft x 1 (1/6)ft... it has two turn arounds in it. Do you guys think this will work? (I run no bass boost, I hate distortion)
here is my design sheet:
Rowan University Electrical Engineering
LINK TO MY BUILDDDDD
Current Setup in my 00' Hyundai Accent:
Pioneer DEH-P6900UB
RE.6.5C AUDIO 500w 6.5" COMPONENT CAR SPEAKERS
Eclipse SE 6500 (6.5 coax in rear deck)
two Kicker C124's in a t-line tuned to 28.6Hz
Kenwood KAC-7204
US amps 1600.4 V2
Upcoming Build this summer:
T-Line enclosure for two C124's tuned to 28ish hz O_O
amp my speakers with a US amps 1600.4.
Second Skin Should be fun ^_^
good luck, srsly, it will bang, made one for a kicker comp 8, and it sounds like maybe a 12. output is just so amazing in tlines....
but i noticed mines sounds so much louder and deeper close or DIRECTLY on the floor. idk if that helps u at all.
and for your first tline, i would personally recommend OSB, dont go blow $30 on mdf to not like the sound of it. just IMO tho.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
thanks bro :) [my 2nd post now btw]. I hope it pounds. cause I already have two kicker C12's in a sealed enclosure and it pounds with like 200rms to each sub. broke my third taillight and my antenna fell off and such.
I'm excited to see what a tline will do to my car O_o hehehe
Pioneer DEH-P6900UB
Kenwood KAC-7204
US amps 1600.4 V2
  • Who's Online   0 Members, 0 Anonymous, 384 Guests (See full list)
