BigPimpin91 Posted June 23, 2008 Report Posted June 23, 2008 i was wondering if any one would like to design me a r-line box for my hd3 12?It's simple give me your sub specs, room you have to work with, and tuning frequency. BigPimpin91's Banging Music
poundindak69 Posted June 23, 2008 Report Posted June 23, 2008 It's simple give me your sub specs, room you have to work with, and tuning frequency. i have 35 wide by 22 deep by 12 high to work with and tuning 28-35(which ever will work best in the space i have)
Forevrbumpn Posted June 23, 2008 Author Report Posted June 23, 2008 That sub wouldnt work to great with the space/tuning you want... Its a higher Fs sub, meaning in a transmission line it will naturally want to play the higher tones... after break in period I would assume 35hz would work, but- you would be more looking at a tline tuned more to 40-45hz a bandpass tline would work best for that sub in my experience I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
poundindak69 Posted June 23, 2008 Report Posted June 23, 2008 That sub wouldnt work to great with the space/tuning you want... Its a higher Fs sub, meaning in a transmission line it will naturally want to play the higher tones... after break in period I would assume 35hz would work, but- you would be more looking at a tline tuned more to 40-45hz a bandpass tline would work best for that sub in my experience ok so you would say 35hz i am good with that if it would work.also i might have another twelve i want to try.
poundindak69 Posted June 23, 2008 Report Posted June 23, 2008 here are the specs i could find on the other 12 its a kick impulse 12i 12 4, 8 150 90 27-1000 5-3/8, 137 11-1/16, 281 1.4-2.1, 39.6-59.4
white_boi_audio Posted June 24, 2008 Report Posted June 24, 2008 Hey forevrbumpn or anybody with good experience in designing t-lines, I have a Q Power "New Deluxe" series 12 inch subwoofer that is 1200 watts probably about 600 rms. I really want to see how a t-line sounds and my demensions are 14 high by 38 wide and about 16 deep. This is for a trunk car so should i face the sub to the back? I can't find any sub specs but I know I wanna hit lows and a little high notes, well basically want it to sound good on all music but freaking slump on rap. "MY RIDE" 1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp -- Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz Coming soon: Bigger Highs Amp, Power inverter "WhItE bOi AuDiO" "FEAR THE DUCK"
BigPimpin91 Posted June 25, 2008 Report Posted June 25, 2008 Hey forevrbumpn or anybody with good experience in designing t-lines, I have a Q Power "New Deluxe" series 12 inch subwoofer that is 1200 watts probably about 600 rms. I really want to see how a t-line sounds and my demensions are 14 high by 38 wide and about 16 deep. This is for a trunk car so should i face the sub to the back? I can't find any sub specs but I know I wanna hit lows and a little high notes, well basically want it to sound good on all music but freaking slump on rap.We, need specs.At least the Fs of the sub to determine where proper tunning is. BigPimpin91's Banging Music
jhmeg2 Posted June 27, 2008 Report Posted June 27, 2008 I have an MTX 4508-04 8" sub in a sealed fiberglass enclosure up front in the kick panel of an Envoy. Its powered by an MTX Thunder 102 (100 watts). I wanted to just take the strain off the mids, but now I just want a little more. I am thinking of trying a slot or a t-line. Slot would be real easy, but i did all the math on a t-line, but just can't seam to figure it out to have the driver and port mouth on the same side. I have space to work with, but it needs to be 46 wide, watever the rest is fine. Can I get some help on it? Fs:34.41 Sd: 39.67, however unfortunatly Qts of it is .582, and Qms is 9.51. Might not be the best but to try it..... what the hell right!!! ////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
BigPimpin91 Posted June 27, 2008 Report Posted June 27, 2008 I have an MTX 4508-04 8" sub in a sealed fiberglass enclosure up front in the kick panel of an Envoy. Its powered by an MTX Thunder 102 (100 watts). I wanted to just take the strain off the mids, but now I just want a little more. I am thinking of trying a slot or a t-line. Slot would be real easy, but i did all the math on a t-line, but just can't seam to figure it out to have the driver and port mouth on the same side. I have space to work with, but it needs to be 46 wide, watever the rest is fine. Can I get some help on it? Fs:34.41 Sd: 39.67, however unfortunatly Qts of it is .582, and Qms is 9.51. Might not be the best but to try it..... what the hell right!!!Not to be a dick but your sig is fucking loooooooong.I suggest a 35hz tuning. Make sure you have the room for it, though. BigPimpin91's Banging Music
aznboi3644 Posted July 1, 2008 Report Posted July 1, 2008 Not to be a dick but your sig is fucking loooooooong. I suggest a 35hz tuning. Make sure you have the room for it, though. yeah seriously take that shit outta there...its annoying. It's called a "Signature" not "Life Story"
