Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
Well, hopefully I will start building this in a week or so, tuned to 30hz, 140 sq.in. of port( measured from surrounds) 108in. long. For the 2 twelves mentioned earlier. Give me you thoughts, keeping in mind I need to add some bracing for the line walls. Also the top is doubled up 3/4".
Posted Image
94' Suburban
Kenwood HU
RF T3002
2x SAZ-1500D's
2x PG Rsd 6.5's
4x RE SE 12'
Kicker Hyperflex 1/0
...more still to come
we could make something up...maybe isobarik loading so the compression chamber can be even smaller to save some room...more motor force...a little higher power handling...it should be good.
cool man, I can't wait.
any luck with the specs?
  • 1 month later...
measure intersections, exit, and behind woofer
for quick reference you can just measure the lines as a whole, you will be off about 2hz, thats not going to hurt to much though...
Got a hold of some 15s temporarily so I get to use atleast 1 until recone parts come in, so I dusted off, and fumigated for spiders ( 40hz test tones )
And cleaned up my ole Iso loaded bandpass Tline, loaded a sub up in it, and ohh so sweet. This box transforms, so its either a iso bandpass, transmission line, ported, or standard bandpass t-line
Felt good to have some beat playing this low with authority again!!
Posted Image
Posted Image
Posted Image
Posted Image
^^ Ugly white door, I had tossed the old regular MDF door, this will have to do
I built these subs about 3 years ago, I ended up selling them to a friend about a year ago, he loved them so much, he used them as trophy pieces, waiting to find a better sub. He went thru L7s, Type Rs, and a few other subs to name a few, and always went back to these. Couldn't blow them, and couldn't find any subs that sounded better
SO, I'am just reconing these from DVC 4ohm to DVC 1ohm, and adding a 3rd spider, and longer coil winding width
Just thought I'd share
  • Who's Online   0 Members, 0 Anonymous, 1444 Guests (See full list)
