aznboi3644 Posted September 28, 2009 Report Posted September 28, 2009 Would a 1/8th wave work? I just want to know all possibilities before I start wasting $30+ sheets of wood. 1/4 wave is WAY to big. if you heavily stuff it yes it will work. But the output will suffer. think about it...1/8 wave 30hz is a 60Hz 1/4 wave. 60Hz 1/4 wave pipe will not go that low
Forevrbumpn Posted September 28, 2009 Author Report Posted September 28, 2009 1/8th waves are fun... I want to try wall lined 1" tuned to about 60hz and monitor the output I know it will work great depending on environment, small car/large car I have a 38hz tline now in my truck, and its dominating the 20hz area, so if I calculated that as 1/8th wave, I would be close to 20hz I'am assuming I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
IH8PunkRok Posted September 28, 2009 Report Posted September 28, 2009 1/8 wave would be at 19 hz for the 38 hz 1/4 wave i got a question. say i have this small sub. and it needs about 16-17 sq inches. but it is impossible to find a five inch pipe besides building a box from mdf what are my options? 4 inch pipe is too small and 6 inch is waay too big i dont have time to build in college. let alone a place to do it. so i want a straight tube if i can. -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Forevrbumpn Posted September 29, 2009 Author Report Posted September 29, 2009 I learned with small drivers first, 4" then 5.25, then 6", and I learned the ABSOLUTELY easiest way possible sit in a car, and just face the woofer cone in to a pvc pipe, use an adapter to fit different sizes I had a 4", and 6" PVC pipe I started off with somewhat long lengths, and actually holding the speaker and pvc in hand, and doing sweeps, and tones to find out what that speaker would peak at, at what frequency, and then I would measure the PVC pipe, cut, or add length to it to fine tune it ALL of this was documented on grid paper, and did little graphs Since I had like 60 Vifa mids and highs from my old employer selling them to me for dirt cheap, it was a easy way to do testing to find out what works, and what doesn't I eventually moved up to Sonotube, then finally started cutting wood So, IH8, you are on the right track to start off small. just buy some pvc, and some adapters to make it longer, or shorter, and document what you find a 4" mid bass firing in to a 4" pipe, and then cut to length gets pretty impressive, not loud, but low and clean. You don't get loud until you start messing with the 6" and larger stuff I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
IH8PunkRok Posted September 29, 2009 Report Posted September 29, 2009 i got a 5 inch sub. so would it be better to go with the 4 inch pipe or inch pipe? 4 inch is closer to required sq inches but less. 6 inch is much bigger -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Forevrbumpn Posted September 29, 2009 Author Report Posted September 29, 2009 i got a 5 inch sub. so would it be better to go with the 4 inch pipe or inch pipe? 4 inch is closer to required sq inches but less. 6 inch is much bigger if you have a jasper jig, and router, cut an adapter that will connect the 5" to the 4" should work fine that 5" only has a sd of about a 4" pipe I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
IH8PunkRok Posted September 29, 2009 Report Posted September 29, 2009 thanks man -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
porkchop Posted October 2, 2009 Report Posted October 2, 2009 does my subs high Qts suggest that the 1/4 wave tline enclosure is not the best for it......how does it effect this overall? it has been sugested perhaps this spec is not truly accurate....on my particular sub, how could i find it on my own? you had said a low Qts, 30 and below would be great..........what is to be expected from 46? thanks chop My daughter's (kimberly) hairtrick via the duckman
rawlins87 Posted October 12, 2009 Report Posted October 12, 2009 built a T-Line yesterday for my 8" Tang Band Neo. 30hz line. Didnt 45 it. But man this this is crazy, only 100wrms on an 8 and it flexing my roof, side mirrors, rear view mirror! T-Line FTMFW
Forevrbumpn Posted October 12, 2009 Author Report Posted October 12, 2009 awsome Rawlins The most impressive designs are with smaller subs, because they really can get so damn low, and a pretty loud audible level I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
