YukonDCXL Posted February 14, 2014 Report Posted February 14, 2014 I am running two DC audio xl 18's in a box tuned to 36hz. What should my lpf be set to?
KillaCam Posted February 14, 2014 Report Posted February 14, 2014 I get so surprised when I see folks with such high end equipment that get lost on the simplest things. No offence towards you. 80ish hz is a safe place to set it. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
YukonDCXL Posted February 14, 2014 Author Report Posted February 14, 2014 Thats what I thought, but just making sure. Know offence taken, you are right on that. I used to have a shop do my stuff and recently after getting screwed by him I decided I could research and do a better job then him. Thanks for the help
KMS Posted February 14, 2014 Report Posted February 14, 2014 Don't forget the subsonic filter too. Alpine PDX-V9 Morel Tempo 6 Alpine SBR-S8-4 Alpine CDE 149BT
YukonDCXL Posted February 14, 2014 Author Report Posted February 14, 2014 I was told that whith 18's to have that knob all the way down
YukonDCXL Posted February 14, 2014 Author Report Posted February 14, 2014 I have strapped amps and my installer had both the phases on 0. I look up the guide and master should be 0 and slave 180... what was this doing to the speaker when they were both on 0?
KillaCam Posted February 14, 2014 Report Posted February 14, 2014 You'd want to set that between 25-30hz. Anything below 25hz is just mechanical noise, air noise, and noise from flex. And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle Chick took 3 shots of Jager, and then, pissed in my mouth.. B5 Passat Build Log
