re audio xxx 15
fx4trucker
I ordered myself a new sub ,. the RE audio XXX 15 . so now im going to build a new box for it .. its a wedge style box with a square port . its gong to be just over 5 cuft after displacements the only thing im wondering is how should I tune it ? low like 32-33hz or high like 37-38hz ?
some more info on the set up
1 woofer .. its dual 2ohm . will be running off of Memphis mojo 2500 watt amp. wired to 1ohm. . I have an on/off switch for the amp so it wont be on all the time. im going for SQL
box measurements
d1-22" d2-16" w-30" h-20" using 3/4" mdf wood. front will be 2 baffles 1.5"s thick
alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers.
1. set is in the a-pilors
1. memphis mojo 2500 watt amp
1. rockford fosgate t2 15"
dual 2 ohm wired to 4 ohm . seeing 600 watts
1. realm audio 600 watt 4ch
Tune low. The xxx is a low end sq monster. I wouldnt put one in a bix tuned over 30hz. I have one myself but its in a huge sealed enclosure to keep a flat response, ran on an AQ2200. Sounds amazing
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
  • Who's Online   0 Members, 0 Anonymous, 3199 Guests (See full list)
