RatBass1998 Posted March 11, 2008 Report Posted March 11, 2008 ok my setup will consist off: 200 amp EA Alt 1 stock battery up front 2 Deep cycles in back im running 1 amp on one sub how will i wire this? dont i run just 1 positive 0 gauge wire to one of the batteries in backfrom the front batt, then hook the back batteries positive to positive and neg to neg then run a 1/0 to my amp, then ground the amp to a neg terminal on a back bat or ground it normally to the frame or somewhere? also how many fuse blocks do i need for this? i counted 3? 1 12" after front bat, 1 12" before back bat and 1 between back bat and amp? im a noob to auxilary battery setups iv always ran 1 under the hood so thanks for the help! 15" LMS Ultra AB VFL 200.1 3kw+ rms@ 1 ohm <-- 500.1 in near furture 3.5 cubes at 34 hertz 2 Exide Orbital's 200 Amp EA Alt 125 sq ft BXT
RatBass1998 Posted March 11, 2008 Author Report Posted March 11, 2008 i really need an answer today guys please respond!! 15" LMS Ultra AB VFL 200.1 3kw+ rms@ 1 ohm <-- 500.1 in near furture 3.5 cubes at 34 hertz 2 Exide Orbital's 200 Amp EA Alt 125 sq ft BXT
roscoe1129 Posted March 12, 2008 Report Posted March 12, 2008 ok my setup will consist off:200 amp EA Alt 1 stock battery up front 2 Deep cycles in back im running 1 amp on one sub how will i wire this? dont i run just 1 positive 0 gauge wire to one of the batteries in backfrom the front batt, then hook the back batteries positive to positive and neg to neg then run a 1/0 to my amp, then ground the amp to a neg terminal on a back bat or ground it normally to the frame or somewhere? you are correct ...then just ground your rear bats to the frame. also how many fuse blocks do i need for this? i counted 3? 1 12" after front bat, 1 12" before back bat and 1 between back bat and amp? you dont have to have the one between the battery and amps but if you feel safer this way go ahead. the fuses are not to protect your amps just the wire and batteries. the amps fuses are there to protect the amp.im a noob to auxilary battery setups iv always ran 1 under the hood so thanks for the help! Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
jmsonoma03 Posted March 16, 2008 Report Posted March 16, 2008 sound right i would put a fuse at battery in front and from the rear bat to amp.no need for fuse in rear before 2nd batunless you are running wire under car and up through hole in rear the fuse is there to protect the car no amps
