My car is an 08 acura tsx with the stock head unit. I have this harness to give me RCA outputs (http://pac-audio.com/productDetails.aspx?ProductId=561&CategoryID=28) running from my head unit to my amp. For a while whenever I would turn on my car it would send a pulse of base to my sub and I would hear a quick "thump". My sub, amp and everything all worked fine until today when I was driving my bass just faded out. The amp still turns on, and the connection is fine to the sub, so are my RCA's blown?
P.S. they are cheap walmart RCA's.
my first thought Is check your ground. the cheap scorshe wires last for ever. they do get loose but I'd still check your ground. and if they are so cheap run some new ones. unlike most i enjoy running wires. its relaxing
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
agree on the relaxing part^
:domodance: :domodance::morepower1:New Build in the Making :morepower1: :domodance: :domodance:
1999 Infiniti I30 Limited
if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Check your ground. Sometimes the power shoots to the amp and if your ground is bad, it will just sit in the amp with nowhere to discharge causing a pop. What kind of amp is it? Some of the cheaper amps don't have the soft start feature that keeps it from popping. I had an amp that wasn't making the popping noise when I first bought it, but after a year or so the pop came in and the amp crapped out.
the kid i talked about a while ago on here with the 2 12s And a 15 on 2 different amps with 6g power wire had a terrible ground. his would pop between songs turning on and off. he'd even get the pop when his door was shut to hard. i told him to fix...well everything but he didn't listen...cuz he knows more then me
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
stock ground? your sharing a ground? what size wire are you using? anything stock just seems bad. It should go to bare metal on the frame of your car
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
The stock bolt is under the floor of my trunk on the bare metal of my spare tire well. I'm using 4 gauge wire.
so thats just sheet metal then. it has to travel all the way up to your struts to get a good ground
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
  • Who's Online   0 Members, 0 Anonymous, 574 Guests (See full list)
