Tallyfiman Posted February 22, 2014 Author Report Share Posted February 22, 2014 my gains are about half way right now im not tryin to push it to hard until i get the second one in i guess thats what he ment by only goin to 2 ohms because he has 2 of them that im gettin but im only puttin 1 in for right now Link to comment Share on other sites More sharing options...
alaskanzx5 Posted February 22, 2014 Report Share Posted February 22, 2014 Your going to burn up voce coils using the gain as a volume knob. Google search smd tool map and find someone in your area in the map with a scope our dd1 t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz. Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted February 22, 2014 Report Share Posted February 22, 2014 I guess you didn't read the last few posts carefully. That sub will not go to 2 ohm's if it's a d2. Get some pics up. Link to comment Share on other sites More sharing options...
Guest Posted February 22, 2014 Report Share Posted February 22, 2014 two woofers one woofer Link to comment Share on other sites More sharing options...
Tallyfiman Posted February 22, 2014 Author Report Share Posted February 22, 2014 alright i get it now 1 can be wired to 1 ohm but the 2 would only be able to go at .5 or 2 ohms Link to comment Share on other sites More sharing options...
Guest Posted February 22, 2014 Report Share Posted February 22, 2014 alright i get it now 1 can be wired to 1 ohm but the 2 would only be able to go at .5 or 2 ohms dont bother with .5 ohm unless you have like $500+ into your electrical setup. and by then theres no point in running a hifonics amp IMO. Link to comment Share on other sites More sharing options...
Tallyfiman Posted February 22, 2014 Author Report Share Posted February 22, 2014 yea i have stock electrical right now but im gettin an alt and some batteries soon hopefully Link to comment Share on other sites More sharing options...
truthsayer Posted February 22, 2014 Report Share Posted February 22, 2014 If your going to be running two of those subs, then it's time to upgrade your amp. Along with electrical like kranny advised. Even with upgraded electrical and alt plus batteries. I wouldn't even attempt to run that amp at .5ohm. And if you keep amp and run at 2ohms your subs are going to be starving for more power. truthsayer Link to comment Share on other sites More sharing options...
Tallyfiman Posted February 22, 2014 Author Report Share Posted February 22, 2014 yea thats what i was thinkin what would be the best amp for them subs then Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted February 22, 2014 Report Share Posted February 22, 2014 What kind of car is this going into? Two 18s will require alot of space. Link to comment Share on other sites More sharing options...
