Looking for Box Design
cbelott
I just purchased a 12" DC Audio LVL 4 subwoofer and a Rockford Fosgate T1500-1BDCP amp. I am looking and willing to pay a little bit of money to someone to help me design the best possible box for it. I need a 1.5 cubic foot ported box, not sure how many square inches of port area are needed or what the box should be tuned to. It's going into a 2014 Subaru WRX, which has a bit of a weird trunk to it. Right behind the seat it comes towards the end of the car 12" then angles down at 45 degrees 7" then flattens back out 18" to the end of the trunk. I was considering a box that has that angle on the bottom of the box to try to leave space for some small items in the trunk if needed. my trunk is 42" wide and as for height, it is 12" high before that 45 degree drop and 17" high after the drop off. I'm wanting a box that really delivers a solid blow, it'll be used daily not going to be entering competitions but i definitely would love a sound that could compete.. Again I'm willing to throw some money somebodies way for the assistance. Thank you very much!
The following should be setup subs/port back, trying port driver's side first, port needs at least 3" of free airspace in front of it, subsonic filter to 28Hz, figure is only an assembly guide :
Port area is 34 3/8 square inches, port volume is 0.949 cubic feet included the internal port walls (sketchup verifiable), port volume is not relevant to the operation of the enclosure.
What you should be clear is that the enclosure have enough clearance to th rear end of the trunk while it doesn't go over that 45 deg slant.
If you would need some tweaking on the dimensions let me know and I will change it.
  • Who's Online   0 Members, 0 Anonymous, 3301 Guests (See full list)
