I'm building my first box this weekend for my gf Pontiac G6. She has 2 Sundown E-10s on a SQ1200. I've been doing my research on box-building the last couple weeks so I think I'm ready to try my first one. I been trying to learn how to use Torres and after about an hour of playing with numbers tonite I came up with a box. Sundown specs suggest 2-2.5cubes for two E10s so I designed a box that is 2.89cubes gross volume and 2.48 cubes net volume and tuned to 33hz. Anyone with experience using the E woofer got any suggestions as to whether this box would be good for the amount of power or does it need to be bigger.
I took a single e10 design and made a dual box for my old setup and it was a good sounding box. I figure your already set on building one or i would try to sell it but if you want that design i could prob find it somewhere
Enclosure Specifications:
Fb = 34.5 Hz
Vb = 1.1 ft^3
External Height = 13 in
External Width = 21.5 in
External Depth = 13 in
Port Width = 1 3/8 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 19 3/8 x 11 1/2
Back = 21 1/2 x 11 1/2
Left & Right Sides:
Side 1 = 11 1/2 x 11 1/2
Side 2 = 12 1/4 x 11 1/2
Top & Bottom = 21 1/2 x 13
L Port Internal Assembly Parts:
Front to Back = 10 1/8 x 11 1/2
Extension = 15 1/2 x 11 1/2
Assembly guide (generic dimensions):
I just combined this design into one single box with the ports facing out the sides and i changed the sub cutout to the side so they can face the front. i thought it might change the sound since the subs are mounted on the side but this box sounds great with any kind of music.
  • Who's Online   0 Members, 0 Anonymous, 1633 Guests (See full list)
