99 Volvo S80 Immobilizer Help
so i was doing an install for a friend today and i got everything up and running except for the damn immobilizer , i am using the 556uw and in the instructions and says that the loop style antenna will not work with european cars..... so it tells me i need to cut into the factory immobilizer wire, only problem is that it doesnt tell me which one it is, there are 5-6 wires come out of the back of the ignition but i dont want to cut into them when im not sure which one is the one i need. ontop of that im pretty sure the tach wire is not correct because even with the key in the ignition, i can get the car to crank but it wont turn on..... i cant learn the tach either. i hooked it up to a light green wire coming from the injector. Need some help guys, maybe a directtechs wiring diagram to compare it to the bulldog one or the one stickied would help.
Too Much Stuff to list .
Posted Image
Posted Image
DC.jpgDC POWER
is this the diagram from directechs? it looks like wiring diagram from bulldog....
