Us amps USA-400...a few questions
Adire
Hello all I need some advice about an amp I'm think of getting. As stated is 99 us amps usa400 , I'm currently running a hifonics 1600d. Now I was given the amp to try out to see if I want it. I hooked it up and was unimpressed with the output, my sub is an adire brahma motor done over by psi to handle the juice. It's wired in one ohm when I ran it briged it didn't work at all, until i used just one channel and then the output was less then what I was expecting, no where near what the hifonics is capable of. Should I pass this amp up or am I overlooking something?
If you ran it at 1ohm mono(bridged) it problem wentin to protect. Here are specs I found for the amp.
2 x 200 watts rms @ 4 ohms
2 x 400 watts rms @ 2 ohms
2 x 600 watts rms @ 1 ohm
1 x 1200 watts rms @ 2 ohm mono.
So to run it bridged the amp will need to see 2ohms not 1 ohm. IMO I would use it over the hifonics any day of the week.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
As to your question of passing it up. I feel you just wired it wrong is why it did not preform the way it should have.
141 on music.
I'm super jealous of the Adire Audio Brahma. Those are from a bit before my time in car audio but I've always thought they are super cool. If the one sub is wired at 1ohm I don't see how you could make much use out of that amp as the Hifonics will outperform just one channel at 1ohm by a good margin. I'd look for another replacement for the Hifonics. Even if you could bridge it at 2ohms I don't think you'll see any performance increase. It's a nicer brand than Hifonics but just doesn't have as much power and you lose a lot of headroom compared to what you're used to.
Ah thanks guys, with my dual 2 the only config I can have are 1 and 4 ohm loads as far as I know of, yea the amp looks badass but 600 is 1k less then it's getting now, I think I agree with john and maybe finding a 2500d or something, so unless there is a way to get 2k from the us amps, although from the looks of the guts it made me kinda upset it want a lot louder, I doubt going to a 4 ohm load would be beneficial.
  • Who's Online   0 Members, 0 Anonymous, 582 Guests (See full list)
