bassman619 04 impala build. 18" in a trunk car
Got the kenwood hooked up all connections soldered n heatshrinked ..tapped into the ignition wire at the ignition switch..its done and turns on and off with the key but no fun being upside dow .
You need trunk space to get groceries and shit...bitches love groceries
Heres the hu installed ..I had to cut some plastic off inside the dash to get it to fit..not too hard I just used a 4" angle grinder then used a hole cutter drill bit to get into the corner where the grinder wouldnt fit..guess gm never intended for a impala to have a doubledin in it. Idk what it is but now I have an alternator whine in my highs ..it was too hot today and I got a little exhausted from the heat so ill do it another
