started my wall 4 american bass 15's 12krms
Are you going to be able to fit that lower passenger side subwoofer in that cutout?
Next time you can draw a line from your center points and make a homemade jig with just a pencil placed into a hole drilled into a skinny piece of wood. Then you can put a nail into the center where you'd like the radius into that piece of wood. This is after you've found the square that perfectly fits around the circumference of your circle. You take a straight line from corner to corner to find your center. Pretty easy, only takes a little extra time measuring.
Good work, always happy to see walls :D
thanks for the advice homie but yea the bottom woofer will fit i tested it yesterday that rubber surround around the mounting hole is really fat but yea after i got done cutting i was dammit but it works..lol
  • 1 month later...
yea so i will post some pics of the changes but in a nut shell took out that f*****n rod plugged the bottom 2 holes untill the other subs get here and put one amp on the top two check out the requested songs
  • 2 months later...
