Opti6000 RCA Input
Hammer Knock
i have been running a opti6k for less then a month and it looks ONE of my RCA INPUTs are messed up and is not wanting to detect any signal. Just ran into this problem today, went back to test it after waiting almost an hour and the problem went away. then i was playing music and it just randomly doesn't work any more. making it sound like almost half the power. BOTH RCA wires have signal coming out of them, as both wires give signal to the RCA INPUT that DOES work. I noticed that when i plug the RCA wire in the OUTPUT rca. it works. but i am not running it like that. any ideas on what to do?
System:
2 x opti1233d subs
1 x opti6000 amp
1 x xs D6500 + factory batt
factory alt
singer 275 amp alt coming soon
if the car doesn't stall, you have enough voltage.
DEH-6400BT
BC3500D on 2 x 12" Lanzar Opti1233d
QBOMB 4.5cu
1/0 awg, Lanzar AMPKIT0
Singer 275 + LCAKT50DBL
took the back off and looked for myself before i sent it back today. this is about the only thing i could find.
did not notice this being connected in any type of way when i tried to wiggle it. i moved the connection this far away from each other to take the pic showing this.
- came loose / never connected right?
- would this cause it?
DEH-6400BT
QBOMB 4.5cu
but mainly, i need to know what to do over all! do an exchange and try another one. or do a refund and say skip that amp and stick with my ap3k for awhile. witch is almost as loud as the 6k @ 1 ohm.
DEH-6400BT
QBOMB 4.5cu
How do you know it's going to be almost as loud if you don't know if you ever had a good amp or not?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
posting threads on forums
DEH-6400BT
QBOMB 4.5cu
So by posting threads on forums you know it's going to be almost as loud as an amp that may not have ever been 100 percent in the first place? Thanks good to know I've been doing it wrong all these years
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i released that. as the amp may not be 100 percent in the first place. as it sounded close to as loud as what i had the ap3k doing (or is that just what it does) . POINT OF THREAD: what is the problem if this is going on with the amp? ( then i was playing music and it just randomly doesn't work any more. making it sound like almost half the power. BOTH RCA wires have signal coming out of them, as both wires give signal to the RCA INPUT that DOES work. I noticed that when i plug the RCA wire in the non working side of the OUTPUT rca. it works)
DEH-6400BT
QBOMB 4.5cu
get something that you can actually buy brand new and not from something you heard once five years ago and the company doesn't exist anymore.
The soldering of two of the jack's center pin connections looks like it was done by someone that has no idea how to solder.
2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab
"Enjoy yourself. It's later than you think."
  • Who's Online   0 Members, 0 Anonymous, 865 Guests (See full list)
