Any Saab owners on here? (anyone can answer)
I have a 2002 Saab 9-5 V6 turbo and I am about to install 0 gauge , but a look under the hood and it is cramp under there. Has anyone run 0 gauge in there car? If so how did you do it, was it through the firewall or did you run it underneath the car?
Side note: the battery is on the left side of the car and if I run the cable straight back I would have to get between the engine, expansion tank and the braking system to get to the only hole that seems to run thru the firewall. Would it be easier to run it under the car?
I dont have a Saab. Sometimes you have to get creative and work with what you have, you may need to drill a new hole - use grommets if you do. Don't forget to fuse 12-18 inches from the battery(ies). GL
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
