Starting with 3 DC 18's, vehicle and power?
I'm curious to see this answer my self. i know that running below 1ohm puts allotof strain on your electrical. for eexample if your system requires 200amps at 1ohm running .5ohm your system can draw almost 400amps. (that's not exact just a exaggerated example) but i don't know how 3 1ohm loads Would be in comparison.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
If you are producing the same total wattage then the electrical requirement from the vehicle is the same. Having one 5000w amp or five 1000w amps needs the same "electrical" from the vehicle when wired properly.
If you wire below what the amp is rated for that means it needs to draw more amps to produce more power than what it was designed for which is hard on the internal components, so if it can get the amperage from the vehicle for what you are trying to produce it makes it easier for the amp to do so. Also you here about voltage drop which is also in the equation. Some amps depending on whats inside do better than others.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
did you just say .067ohm ????
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
Wouldn't this only hold true if the amplifiers were equally efficient?
04 Honda Accord LX Sedan
Kenwood Excelon X998
XS Power D3400
XS Power D1200
Singer 275A alternator with factory bypass
64 sqft SecondSkin Damplifier
Build to be decided
:peepwall:
i thought a 1000w amp at .5 would draw more power.then a 1000w Amp at 1ohm. even if the 1000w at .5 was designed to run at .5
(this is what I've heard) I'm just asking a question.
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
Sorry decimal in wrong place, meant 0.67 ohm with 3 subs wired together.
Yes the assumption was that . If the true output from 5000w amp at 1 ohm is 5000w and the output from the five 1000w amps at 1 ohm is 5000w then the required amperage is the same again assuming that the voltage is the same in both which may not be true with all the additional wire running 5 amps. May point is that there is not a significant difference.
Yes
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
that makes me happy, i heard that here. it's nice to know i can Trust what most people say here.
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
So what would you do. i have a brutus 2400 now. Get 2 more for about $600 to run each sub or get a stetsom 6k5es for about $1000 to run all 3. Not which one is better, but which is better for install, more subs means more wire, fusing, etc. but it will cost less.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
that's tough. I've always wanted one big Amp! I'll be running 2 2000w amps soon. idk id say get the big amp sell the smaller one to help pay for the gear your gonna need. just my 2cents.
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
Yeah probably keep it simple
Also may just do a collaboration and use my vehicle, split the cost, sounds like a good deal to me.
Just have to figure if 3 18's will fit walling behind c pillar without taking out the back seat. Plus gotta put the amp and batteries somewhere. Might have to do typical subs up and port back.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
  • Who's Online   0 Members, 0 Anonymous, 2622 Guests (See full list)
