advice for car audio noobie
Rooles, if your planning on running your power wire or any cables under the car. Use pvc pipe and run inside of it. Then secure the pipe to the frame.
truthsayer
I would use a decent amount of wood glue and that will seal the seams and hold it together. A router and a jig is the easiest way to cut a hole for the subs. You can also use a jig saw. But a jig saw will be a little bit sloppy. Even if you are really good. Router and jasper jig is my favorite way to cut holes.
Oh yeah two more things
It is possible to get wires into the amp without any pubes sticking out. Make take a few tries but it's doable. Remember: even one strand is a potential hazard for shorting out
And not everything needs to be torqued to 1049lbs. Snug works for most things. Too tight and they strip, too loose and the connection sucks
  • Who's Online   0 Members, 0 Anonymous, 574 Guests (See full list)
