advice for car audio noobie
i actually have a very similar cord it has a female 3.5 headphone to two female rca cable. I will try it out and post my results. In general its best to have the sub box facing the rear of the car correct? rather than it facing the inside of the car? Also one of the RCA inputs on the amp had the center piece come out. i am speaking with soundqubed about it to see what can be done. it still works with one input for the moment.
Burned CDs are not the same as originals. Usually the have been ripped at a lower bit rate than optimal and then burned. So I'm going to be so bold and say that it is the poor quality of the music you have and not the system.
Using an original cd did not help. Using my phone to send the signal directly to the amp seemed to have a cleaner bass but did not help with the higher bass tones. Should i try to put the low pass filter to 200hz and see if that helps at all? Its set to what i think is 100-110 hz
Or his car might simply just not like those frequencys.
Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird..
He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke.
2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe
subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12
Amp: pioneer gm9061 amp: poineer gm9601
headunit: kenwood kdc 255u mids: SQ pro mids
midbass: polk db 8s highs: stock
mids/highs: shitty off brand
You guys dont think it may just be the box? I did build it myself and it is my first one. Im pretty frustrated at this point
