SlamminBeats Posted March 28, 2014 Report Posted March 28, 2014 My headunit keeps cutting off when the volume reaches a certain point. it just shutoffs and than turns right back on and usually when the midbass from the speakers hits. Why could this be? It seems like a power issue and not signal. The deck is getting super hot too. Whats weird is if i reset it, this all goes away until i turn the car off and try to restart it, then everything starts cutting out. Checked if speakers were shorting out by unplugging one at a time to see if it stopped. FAIL Checked HU connections for power/ground/ignition FAIL Checked PICO fuse in back and its not blown FAIL Tightened all grounds even though i have plenty if one were shitty. FAIL put volt meter to power while it was cutting out and it still gave me 12 volts. FAIL
ImaNoob Posted March 28, 2014 Report Posted March 28, 2014 Same thing happened here, my problem was the ground on the factory harness, 12 pin or whatever.. it was a little loose in the plug..Radio was getting hot and shutting off..Worth a shot to look 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
SlamminBeats Posted March 29, 2014 Author Report Posted March 29, 2014 i just re tightened the ground at the back of deck. no issues sense. i believe its gone when it lasts a whole day
